Style Manager
The Style Manager provides a centralized interface for managing all of your built-in and Custom Styles. It gives you complete control over which Styles appear in menus, their order, keyboard shortcuts, and more.
Opening the Style Manager
To open the Style Manager, click the Manage Styles… button in the pane, or use (⌥+⇧+⌘+M). You can also drag CSS files directly onto the preferences window — Marked will import them, open the Style Manager, and select the newly added row for you.
The Style Table
The Style Manager displays all of your styles in a sortable table that mixes built-in and custom styles seamlessly. Each row in the table contains several columns:
Enabled Checkbox
The Enabled checkbox immediately adds or removes the style from the Style menu, Default Style popup, and keyboard shortcuts. When you disable a style, it’s hidden from menus but remains in the Style Manager for easy re-enablement.
If you disable the currently active style, Marked automatically switches to the next available enabled style.
Name Column
The Name column displays the style’s display name. You can edit this name inline by clicking directly on it; changes persist and propagate to every menu where the style appears. This is especially useful for custom styles where you might want a more descriptive name than the filename.
Built-in styles have locked names that cannot be edited. To customize a built-in style’s name, duplicate it first to create an editable copy.
Source Column
The Source column indicates where the style comes from:
- Built-in: Styles that come with Marked and are stored in the application bundle
- Custom: Styles you’ve added from CSS files on your drive
- Duplicated: Styles created by duplicating another Style (either built-in or custom)
Actions Column
Each row includes an Actions stack with buttons for managing that Style:
Edit: Opens the CSS file in your default editor. Built-in styles cannot be edited directly – you’ll need to duplicate them first to create an editable copy.
Duplicate: Creates a copy of the style and a new CSS file on disk. The duplicate appears immediately below the original style in the table. This is the recommended way to customize built-in styles.
Reveal: Shows the CSS file in Finder, making it easy to locate the file on your drive. This button is only available for custom styles with a file path.
Delete: Removes the style from Marked. For custom styles, you’ll be given the option to either remove just the reference (keeping the CSS file) or move the CSS file to the Trash. Built-in styles cannot be deleted, but they can be disabled.
Restore: For built-in styles, this button restores the style to its default state if it has been modified. This button is only visible for built-in styles.
Reordering Styles
Rows can be reordered via drag and drop. Simply drag a style row to a new position in the table. The order you set here drives:
- The Style menu order in Marked’s menus
Keyboard shortcut assignments (
⌘1–⌘9for the first nine enabled styles,⌥⌘1–⌥⌘0for the next ten, and so on)
Drag styles into the keyboard shortcut slots you want them to occupy.
Adding Styles
There are several ways to add new custom styles to the Style Manager:
Add Button
Click the Add New Style button to open a file picker where you can select one or more CSS files to import. Selected files will be added to the Style Manager and enabled by default.
Drag and Drop
You can drag CSS files directly onto the Style Manager window. When you drag files over the window, an overlay will appear showing “Add a Custom Style” (or “Add N Custom Styles” for multiple files). Drop the files to import them.
You can also drag CSS files onto specific positions in the table — the drop indicator shows where the new style will be inserted, allowing you to control both import and positioning in one action.
Dragging CSS files onto the preferences pane will also import them and open the Style Manager automatically.
Live Preview
The right pane of the Style Manager displays a live preview of the selected style. The preview renders a comprehensive sample document with headings, lists, tables, code blocks, blockquotes, and other common Markdown elements, all styled with the actual CSS from the selected style.
The preview uses the CSS file directly from disk, so any edits you make in your external editor will update instantly in the preview. This makes it easy to see your changes in real time as you develop custom styles.
Dark Mode Preview
A checkbox above the preview allows you to toggle between light and dark mode previews. This is useful for testing how styles look in both appearance modes, especially if you’re creating styles that adapt to system appearance.
Keyboard Shortcuts
The Style Manager displays a legend below the table showing how keyboard shortcuts are assigned. The first nine enabled styles receive ⌘+1 through ⌘+9 (⌘+0 is reserved), the next ten receive ⌥+⌘+1 through ⌥+⌘+0, and so on. You can see the assigned keyboard shortcuts in the Style popup menu on any Preview.
Filtering Disabled Styles
A checkbox at the bottom of the window allows you to show or hide disabled styles. When unchecked, only enabled styles are displayed, making it easier to focus on and reorder your active styles. When checked, all styles (enabled and disabled) are shown, allowing you to manage your complete style collection.
Restoring Built-in Styles
The Restore built-in styles button at the bottom of the window opens a confirmation that re-enables built-in styles. The alert title is Restore Default Styles. Choose Keep Current Order to leave the Style menu order as-is, or Restore Default Order to reset built-in ordering as well. Use this if you have disabled built-in styles and want them back, or if you want to undo modifications to built-in styles.
Tips
Organize by frequency: Drag your most-used styles to the top to give them the easiest keyboard shortcuts (⌘+1, ⌘+2, etc.)
Disable instead of delete: Rather than deleting styles you’re not using, disable them. They’ll stay out of your way but remain available if you need them later.
Use duplicate for experimentation: Duplicate a style before making major changes so you can always return to the original.
Preview while editing: Keep the Style Manager open while editing CSS files to see your changes update in real time in the preview pane.
Batch import: You can select multiple CSS files at once when using the Add button, or drag multiple files to import them all in one action.
