Settings: Style
Options in the Marked Settings, Style pane:
Settings: Style
Settings: Style
Layout and typography
Limit text width in Preview
Set a maximum width for the body of the preview using the slider (in pixels).
Auto-hyphenate in paragraphs
Allow words to break with hyphenation automatically.
Prevent widows in headlines and paragraphs
Forces a non-breaking space between the last two words of headlines and paragraphs to prevent single words from wrapping to a new line.
Generate typographically correct quotes and punctuation
Use SmartyPants for smart quotes, ellipses conversion, and other typography features (MultiMarkdown).
Surround footnotes markers with square brackets
If checked, use the default MultiMarkdown formatting for footnote markers ([1]). Uncheck to strip square brackets.
Enable Outline for extensions
Automatically turn on Outline mode for files with listed extensions.
Use APA Style
Use APA style outlines instead of the default Decimal format.
Style verbatim (code) blocks as poetry
If checked, tab-indented, fenced or included code is displayed as poetry instead of a code block (no syntax highlighting, and special styling depending on the theme).
Allow themes to wrap text inside code blocks
If checked, themes are allowed to cause wrapping within pre>code blocks. If unchecked, horizontal overflow will always scroll.
Always wrap code
Force code blocks to wrap regardless of theme settings (overrides theme wrapping behavior).
Detect and style RTL text
Detect language per element in document and style Right To Left accordingly.
Theme
Manage Styles
Opens the Style Manager window. Add CSS files from your drive to have them appear in Style picker menus. Use the Add New Style button or drag CSS files to this window. Drag to reorder, and use the checkboxes to enable or disable Styles.
More Themes
Open the online theme gallery to browse and install additional styles.
Default style
The style selected here will be loaded for all new windows, unless a document-specific style is indicated in metadata (e.g. “Marked Style: Grump”).
Track CSS changes
When this is enabled, Marked will watch the current Style for disk changes, aiding in custom style editing and web development.
Additional CSS
CSS added here is appended after the normal stylesheet for every theme. It is a partial overlay, not a full theme substitute.
Marked rewrites selectors in this field (for example, print rules should use body.mkprinting #wrapper …). There is no size or validity gate — see Creating Custom CSS.
This applies to all documents and all styles, including HTML export when styles are included. If you want to apply custom CSS to documents based on conditions, use Custom Rules under Marked Settings, Processor pane.
Include Scripts
Syntax Highlighting
Turn on highlight.js syntax highlighting for code blocks. Select a theme from the dropdown.
If Only if language specified is checked, syntax highlighting will only be applied to fenced code blocks with a language specified.
Enable MathJax
Loads MathJax for displaying MathML equations. Choose Local (bundled) or CDN from the dropdown.
Additional Packages opens a sheet to include extra MathJax packages (for example Physics and Chemistry).
Advanced Configuration opens a sheet for custom MathJax configuration.
Enable KaTeX
Loads KaTeX as an alternative to MathJax. Only one or the other may be selected.
Number equations
If applicable, Marked will add figure numbers to rendered equations. Choose Left Side or Right Side for numbering. If using MathJax, you can choose AMS only to number only AMS equations.
Mermaid
Loads mermaid.js from a CDN to enable Markdown-style diagramming. The hook required to render Mermaid diagrams on every document update is included automatically.
Pan and zoom diagrams
When Mermaid diagrams are present, enable zoom with -scroll and pan by clicking and dragging.
Next up: Settings: Processor
