Opening Files
Marked gives you options.
Live preview workflow
- Drag a Markdown file onto Marked (or use (⌘+O)).
- Edit the file in your preferred editor.
- Save — Marked updates the preview automatically.
See Live Markdown Preview on Mac for vault watching, streaming preview, and editor-specific guides.
Drag to Dock Icon
The easiest way to use Marked on a file you’re already editing is to drag the document icon from the toolbar of your editor or from Finder to the Marked icon in your Dock. Marked will immediately start tracking any Markdown file (or text file) dropped on it. You can also drag files directly from the Finder.
Using the Menu
You can, of course, open Markdown files directly using the (⌘+O) menu option. Marked works fine without a text editor, too. You can preview and convert your Markdown with just a click.
Marked can also open .rtf and .rtfd files directly (for example exports from Pages or TextEdit). They are converted to Markdown for preview and update when you save in the original app. See RTF and RTFD Support for details, including images and limitations.
Marked can open .pdf files the same way: conversion runs in the background, then the preview updates when finished. This works best for shorter, text-based PDFs; large manuals and scanned documents are slower and less accurate. See PDF Support for details and limitations.
From the Clipboard
If you have compatible (e.g. Markdown) text in your clipboard, you can open an instant preview by selecting (⇧+⌘+V). If you copied a selection from a web browser or other app that put HTML or RTF on the clipboard, Marked converts it to Markdown for preview. When you paste RTF from an app like TextEdit or Pages, larger font sizes are roughly converted to heading levels (e.g. very large text becomes a level 1 heading, smaller large text becomes level 2, and so on). You can have multiple clipboard previews open at once, and you can save them to a new file by choosing .
Creating a New Document
Marked allows you to create a new, empty text file with the (⌘+N) command. It will immediately ask you for a location to save the file, and you can enable the “Edit new files automatically” option in the , next to the Text editor button to automatically open the newly-created file in your default editor.
Open Recent
Marked keeps track of recent documents, too. The menu option will show you the files you”ve had open and let you jump back to them. You can quickly re-open the last file you were viewing with ⇧+⌘+R. Use ⇧+⌘+P or Quick Actions to run menu and preview commands from the keyboard. There are a lot of other keyboard shortcuts, too. If you care to learn them, you can find a chart under Keyboard Shortcuts.
New View into Current File
Use (⇧+⌘+N, also in the preview context menu) to open a second preview window on the same saved file. Both windows watch the file on disk and update when you save in your editor, but each view keeps its own scroll position, bookmarks, preview style, and Custom Rule overrides.
Example use case: You are editing a long manuscript in MultiMarkdown with your usual style and processor. Open a second view, switch it to a proofing style, pin a Process rule that runs a different built-in processor, and enable a manual rule that highlights revision markup. You compare draft and proof layouts side by side without maintaining two copies of the file.
When more than one view of a file is open, the window title includes View 2, View 3, and so on so you can tell windows apart in the Window menu and Mission Control.
Alternate views are not available for unsaved documents, clipboard previews, streaming previews, or folder-based projects that do not map to a single file on disk.
Quick Open ##
You can quickly switch between open documents, open recent documents, or open the File->Open dialog with the Quick Open panel (⇧+⌘+O).
