Keyboard Shortcuts
A floating panel with a shortcut cheat sheet is available from the Help menu, or by pressing ⌥⌘K.
Shortcuts
| Shortcut | Function |
| ⌘, | Settings |
| ⌘N | New File |
| ⌘O | Open |
| ⇧⌘O | Quick Open |
| ⇧⌘P | Quick Actions |
| ⇧⌘R | Re-open Last |
| ⌘W | Close |
| ⌘P | Print/Save PDF |
| ⌘S | Save HTML |
| ⇧⌘S | Save RTF |
| ⌘C | Copy |
| ⇧⌘C | Copy HTML Source to clipboard |
| ⌘U | Toggle Source View |
| ⌘T | Toggle Table of Contents |
| ⌘R | Reload Preview |
| ⌘1-9 | Select Built-in Style |
| ⌥⌘1-9 | Select Custom Style |
| ⌘/ | Gear Menu |
| ⇧⌘= | Increase Text Size |
| ⇧⌘- | Decrease Text Size |
| ⇧⌘0 | Reset Text Size |
| ⌘M | Minimize |
| ⌥⇧⌘F | Keep on Top |
| ⌃⌘B | Show Boundaries of Included Files |
| ⌃⌘L | Validate External Links |
| ⌃⌘W | Visualize Word Repetition |
| ⌃⌥S | Toggle Speed Read |
| ⌃⌥R | Toggle Reading Mode |
| ⇧⌃⌘I | Ask About Document (Apple Intelligence) |
| ⌥⌘S | Basic Statistics |
| ⌥⇧⌘S | Readability Statistics |
| ⌘I | Detailed Statistics |
| ⌥⌘C | Toggle Custom Processor |
| ⌘F | Search |
| ⌘G | Highlight next match |
| ⇧⌘G | Highlight previous match |
| ⌥⌘← | Collapse all sections |
| ⌥⌘→ | Expand all sections |
| ⇧⌘V | Preview Clipboard |
| ⌘K | Markdownify URL |
| ⌃⌘S | Save Clipboard Preview |
| ⌘\ (Backslash) | Toggle Fountain/Scrivener Comments |
| ⌃⌘C | Toggle Comment Sidebar |
| ⌥⌘F | Filter Scrivener Documents |
| ⌥⌘K | Show Keyboard Shortcuts |
| ⌥⌘M | Show Markdown Reference |
Quick Toggles
Extra keyboard shortcuts for toggling common global settings.
| ⌃⌥⇧L | Retain Line Breaks |
| ⌃⌥⇧I | IDs on Headlines |
| ⌃⌥⇧Y | Strip YAML |
| ⌃⌥⇧M | Strip MMD Metadata |
| ⌃⌥⇧S | Scroll to First Edit |
| ⌃⌥⇧C | CriticMarkup Always |
| ⌃⌥⇧T | Smart Typography |
| ⌃⌥⇧H | Process Inside HTML |
Preview Navigation
Press “?” at any time to view the following shortcuts in the Preview window.
| t or gg | Jump to Top |
| b or G | Jump to Bottom |
| ⇧1-9 | Bookmark Scroll position |
| ⌥1-9 | Bookmark Nearest Headline |
| ⌘D or `` | Add next available bookmark |
| 1-9 | Scroll to Bookmark |
| 0 | Display Mini Map |
| N/P | Next/Prev Bookmark Numerically |
| n/p | Next/Prev Bookmark in Page Order |
| j/k | Scroll Down/Up |
| J/K | Scroll Up/Down Faster |
| ,/. | Navigate All Headers |
| </> | Navigate H1/H2 Headers |
| e | Jump to Most Recent Edit Point |
| c/C | Cycle comments and footnotes |
| s | Auto-scroll |
| S | Reverse Auto-scroll |
| ⇧←/→ | Speed up/Slow down auto-scroll |
| f | Open “fast switcher” |
| I | Display current included filename |
| z | Zoom Overview toggle |
| \[** / **\] | Navigate target highlights |
| { / } | Navigate all highlights |
| Escape (⎋) | Close Overlay/Deselect Text |
| h/? | Show/Hide Help HUD |
| ⇧⌘F | Focus view |
Reading Mode
While Reading Mode is active, j/k move by reading unit instead of scrolling, and h highlights instead of opening this HUD (press ? for the HUD).
| j/k or ↓/↑ | Next/Previous reading unit |
| h | Highlight selection or toggle current unit |
Table of Contents Navigation
When the Table of Contents is open, you can navigate via keyboard.
| ⌘T | Open TOC |
| j/↓ | Select first/next item |
| k/↑ | Select previous item |
| o | Scroll to selection |
| Space | Open TOC quick-search |
| ↓/Tab | Select first search result |
| Escape | Clear search/Dismiss TOC |
