Settings: Export
Options in the Marked Settings, Export pane:
(See Exporting for more info)
Settings: Export
Settings: Export
Export Profile
Export Profile
Select a saved profile from the popup menu. Profiles store a complete set of export preferences for quick switching between workflows (for example, print PDF vs. web HTML). See Export Profiles.
New
Create a new profile from the current settings.
Manage
Open the profile manager to rename, duplicate, or delete profiles.
Print/PDF
Disable links/highlights when exporting PDF or Printing
Removes formatting (underline and color) from links when printing.
Include URL as text annotation
When printing or exporting PDF, the URL for a link will appear after the linked text.
Replace horizontal rules with page breaks
Turn horizontal rules in document into page breaks (this will additionally force footnotes onto a new page).
Embed images when copying HTML
When enabled, copying HTML to the clipboard will scan for local images and Base64 encode them to include as data URLs in the source code.
Print background colors and images
By default Marked will print/export with a white background. If you want to include background colors and images from custom themes, enable this option.
Show comments in Print/PDF
Include CriticMarkup, Scrivener, Word, and Fountain comments as highlighted inline text when printing or exporting PDF. Footnotes already appear in the document body and are unchanged.
Prevent orphaned headlines
This option prevents headlines for the next section from appearing at the bottom of a page without succeeding content.
Exclude first H1
Ignore the first level-one headline in the document when using H1s as page breaks.
Use first H1 as fallback title
When using apps like Bear or the streaming preview, this option allows you to override the filename with the content of the first H1 in the document. If metadata for “title” is specified, that will always take precedence.
Add page breaks before
Use level 1/2 headers as section dividers, always starting them on a new page. Select “Footnotes” to always add a page break before any footnotes in the document.
Indicate page breaks in preview
Show a light dashed line where breaks are inserted with <!--BREAK--> syntax or by checking auto-break options in Export settings.
Custom font size for export/print
If set, all text will be scaled based on the point setting selected (defaults to a base of 10 points).
Margins
Define print margins (specified in points) for top, bottom, left, and right.
Print table of contents
Include automatic table of contents in print/PDF.
Page Break after
Automatically break to a new page after an inserted Table of Contents.
Table of contents level markers
Use the dropdowns to set the list item marker for each level of indentation in a table of contents.
Headers and Footers
Configure font, logo, header/footer fields, date and time formats, first-page inclusion, page numbering offset, and borders. Field placeholders include %title, %logo, %page, %total, %date, %time, %h1, %h2, and others.
See Headers and Footers in Exporting for placeholder reference and examples. See Date and Time Formats for %date and %time format codes.
Include on First Page
If the option for header and/or footer are unchecked, the first page will not print the specified type.
Date format
strftime-style format string for %date in headers and footers. See Date and Time Formats.
Time format
strftime-style format string for %time in headers and footers. See Date and Time Formats.
Page numbering offset
Used to adjust what number the page numbers start at. For example, if you have a table of contents on the first page and want the numbering to start on the second page, set the offset to -1. Page 2 will now be page 1 and the total pages will be adjusted accordingly.
Border
Print a horizontal line below the header and/or above the footer.
Restore Default Formats
Reset date and time format strings to Marked’s defaults (%m-%d-%Y and %I:%M %p). See Date and Time Formats.
Next up: Settings: Advanced
