Discount GFM Specification
Check out the Markdown Dingus to experiment with the Discount processor.
What is Discount GFM?
Discount GFM (GitHub Flavored Markdown) is a C-based Markdown processor that implements GitHub’s extended Markdown syntax. It’s based on the original Discount library but enhanced with GitHub-specific features like tables, task lists, strikethrough text, and automatic URL linking.
Key Characteristics
  • C-Based Performance: Fast, native C implementation for optimal performance
  • GitHub Compatibility: Implements GitHub’s Markdown extensions for maximum compatibility
  • Lightweight: Minimal dependencies and small footprint
  • Extensible: Supports various Markdown extensions and custom options
  • HTML5 Support: Generates modern HTML5 output with proper semantic markup
Major Differences from Standard Markdown
1. GitHub Flavored Markdown Extensions
Tables
  • Full support for GitHub-style tables with alignment options
  • Headers, separators, and data rows with proper HTML table structure
  • Column alignment using colons (:) in separator rows
| Header 1 | Header 2 | Header 3 |
| Left     |  Center  |    Right |
| Aligned  | Aligned  |  Aligned |
Task Lists
  • Support for GitHub-style checkboxes in lists
  • Interactive checkboxes (rendered as HTML input elements)
  • Both checked and unchecked states supported
- [x] Completed task
- [ ] Pending task
- [x] Another completed task
Strikethrough Text
  • Text enclosed in double tildes (~~) becomes strikethrough
  • Uses HTML <del> tags for semantic markup
  • Supports multiple tildes for emphasis
~~This text is crossed out~~
~~Mistaken text that should be removed~~
2. Enhanced Code Block Support
Fenced Code Blocks
  • Triple backticks (```) for code blocks
  • Language specification for syntax highlighting
  • No indentation required (unlike standard Markdown)
```javascript
function hello() {
  console.log("Hello, World!");
**Automatic Language Detection**
- Support for many programming languages
- Proper [syntax highlighting](Features_For_Coders.html) when supported
- Fallback to plain text for unsupported languages
### 3. **Automatic URL Linking** [3-automatic-url-linking]
**URL Autolinking**
- Automatic conversion of URLs to clickable links
- Support for http, https, and ftp protocols
- Email addresses automatically converted to mailto links
```markdown
Visit http://example.com for more information.
Contact us at user@example.com
Smart Link Detection
  • Recognizes URLs without explicit markup
  • Handles various URL formats and protocols
  • Configurable link safety options
4. Advanced List Features
Alphabetic Lists
  • Ordered lists with alphabetic markers (a, b, c, etc.)
  • Automatic progression through the alphabet
  • Proper HTML <ol type="a"> output
<!-- apex-alpha-list-lower -->
1.  First item
2.  Second item
3.  Third item
Enhanced List Processing
  • Better handling of nested lists
  • Improved spacing and indentation
  • Support for mixed list types
5. Footnotes Support
Reference-Style Footnotes
  • Automatic footnote numbering
  • Reference links with [^1] syntax
  • Footnote definitions at document end
This is a sentence with a footnote[^1].
[^1]: This is the footnote content.
Automatic Footnote Processing
  • Generates proper HTML footnote structure
  • Links between references and definitions
  • Sequential numbering throughout document
6. HTML Integration
HTML5 Support
  • Full HTML5 tag recognition
  • Proper semantic markup generation
  • Modern HTML structure and attributes
Raw HTML Blocks
  • Support for HTML within Markdown
  • Proper escaping and sanitization
  • Integration with Markdown syntax
7. Enhanced Emphasis Rules
Relaxed Emphasis
  • Single underscores (_) don’t create emphasis in the middle of words
  • Better for documenting code and technical content
  • Prevents unwanted emphasis in identifiers
This is a variable_name that won't be emphasized.
This is _emphasized text_ that will be styled.
Multiple Emphasis Levels
  • Support for bold, italic, and combined emphasis
  • Consistent with standard Markdown emphasis rules
  • Proper HTML output with <strong> and <em> tags
8. Table of Contents Generation
Automatic TOC
  • Generates table of contents from headings
  • Hierarchical structure based on heading levels
  • Configurable TOC generation options
Heading ID Generation
  • Automatic ID generation for headings
  • Anchor links for easy navigation
  • Consistent ID formatting
Discount GFM vs Other Markdown Flavors
Feature Discount CommonMark (GFM) Kramdown MultiMarkdown Standard
Tables Yes No Yes Yes No
Strikethrough Yes No No Yes No
Task Lists Yes No No Yes No
Fenced Code Yes Yes Yes Yes No
Math No No Yes Yes No
Footnotes Yes No Yes Yes No
Definition Lists No No Yes Yes No
Abbreviations No No Yes No No
Attribute Lists No No Yes No No
Extensions Limited No Yes Yes No
Typography Basic No Yes No No
Autolinks Yes No No No No
Alphabetic Lists Yes No No No No
Key Advantages of Discount GFM
  1. GitHub Compatibility: Perfect for content that needs to work on GitHub
  2. Performance: Fast C-based implementation
  3. Simplicity: Focused on core GitHub features without complexity
  4. Reliability: Stable, well-tested implementation
  5. Standards Compliance: Follows GitHub’s Markdown specification
  6. Lightweight: Minimal resource usage and dependencies
Common Use Cases
GitHub Documentation
  • README files and project documentation
  • GitHub Pages and wikis
  • Issue and pull request descriptions
Technical Writing
  • Code documentation and tutorials
  • API documentation
  • Technical specifications
Content Management
  • Blog posts and articles
  • Documentation websites
  • Knowledge bases
Collaborative Editing
  • Team documentation
  • Project planning documents
  • Meeting notes and minutes
Configuration Options
Discount GFM supports various configuration options:
  • Auto-linking: Enable/disable automatic URL detection
  • Footnotes: Control footnote processing
  • Table of Contents: TOC generation settings
  • HTML Safety: Link validation and sanitization
  • Strict Mode: Enhanced parsing rules
  • Smart Quotes: Automatic quote conversion
Implementation Details
Parser Options
  • kGHMarkdownAutoLink: Enable automatic URL linking
  • kGHMarkdownFootnotes: Enable footnote processing
  • kGHMarkdownTOC: Enable table of contents generation
  • kGHMarkdownSafeLinks: Restrict links to safe protocols
  • kGHMarkdownNoHTMLTags: Disable HTML tag processing
Output Features
  • HTML5 semantic markup
  • Proper heading hierarchy
  • Accessible table structures
  • Clean, valid HTML output
Best Practices
  1. Use Tables Sparingly: Tables are powerful but can be complex to maintain
  2. Leverage Task Lists: Great for project management and documentation
  3. Utilize Autolinks: Let the processor handle URL conversion automatically
  4. Structure with Headings: Use proper heading hierarchy for better TOC generation
  5. Test on GitHub: Verify compatibility with GitHub’s rendering
Migration from Standard Markdown
Most standard Markdown works with Discount GFM without changes. To take advantage of GFM features:
  1. Add Tables: Convert data into GitHub-style table format
  2. Use Task Lists: Replace bullet points with checkboxes where appropriate
  3. Enable Strikethrough: Use ~~text~~ for crossed-out content
  4. Leverage Autolinks: Remove manual link markup for simple URLs
  5. Structure Headings: Ensure proper heading hierarchy for TOC generation
Resources
This documentation covers Discount GFM as implemented in Marked. For the most current information, always refer to the official GitHub Flavored Markdown specification.
Next up: Credits
